Installing Pioneer Avic f700BT
much appreciated If I could I would give you a rep but I can't as this isn't Slickdeals :P
The instructions are nice but it does not show how to remove the plate :/
You might want to reconsider splicing wires. If you buy an onstar retention harness or a standard harness adapter, either will plug into the factory connectors. That's a much better idea than getting in and cutting what's there.
As FloridaFeMan said, put your fingers in the power outlets and pull out. Then get your finger under the edge and pull out as you work your way up. It'll be a bit stiff, but pull with steady pressure and it'll come lose.
Well ok that much I figured as I have done an install or two in the past, I thought you were saying I wouldn't have to cut and splice at all that would be awesome.
You don't have to cut / splice anything from the truck, in fact you should avoid that completely.
You need the GMOS-04 to retain OnStar and work with the Monsoon system.
There are detailed instructions for the F700BT and the GMOS-04 that tell you which wires you need to connect on the F700BT's harness and the GMOS-04's harness. Then you literally just plug the GMOS-04 into the truck and the F700BT's harness in to the head unit.
To get the dash trim off, as has been stated, stick your fingers in the accessory power ports and pull out and slightly up. Once you have enough of a gap, slide your fingers in and pull outwards. There are several clips around the perimeter of the trim piece that are just compression fit into the dash, they will pop out (no worries of breaking them). I've had mine off 5 or 6 times now, nothing to it. It helps to shift into 1st (automatic) or 2nd (manual) to give yourself some more clearance. Once the trim piece is off there are 6 connections (6 ish anyway) that you need to disconnect and you're done.
The H3 was by far the easiest stereo install I have ever done in my life. Tons of room to work and tuck wires away.
Good luck!
Good luck!
Autum Thanks ! Since you installed one in urs maybe you can suggest something. The Radio instructions, or perhaps GMOS, state I need to connect a wire to the reverse signal light wire so that radio has the correct location for the car, if I do not connect this wire will navigation possibly be affected? or is this only if you have a rear view camera? Also one of the wires need to go to the parking brake power cable, any suggestions as to where to find it ? or is there already a wire in there I can connect to?
All the wiring that you will need to do will be done through the GMOS-04. The parking brake and reverse wires are part of that system. No need to wire anything in outside of the GMOS.
The reverse wire is so that the HU knows when the truck is in reverse so that it can activate the rear view camera. The parking brake cable is so that the HU knows that the parking brake is engaged so that it will unlock the video and GPS features (there are ways around this... check Google and YouTube).
