I'm so excited about new taillights I just got :)))
Old Jun 9, 2021 | 05:56 PM
UcraDen's Avatar
Default I'm so excited about new taillights I just got :)))
Today installed that happiness ) along with sticker on the rear window )))
Almost jerking off on it ))
Old Jun 9, 2021 | 06:12 PM
Looks good. Why do you haul around a spare that don't match?
Btw, I have the same oem spare tire(never used) planted in my back yard, dated 2406(24th week 2006). DO NOT ATTEMPT TO DRIVE ON IT!
Old Jun 9, 2021 | 06:50 PM
UcraDen's Avatar
)) the spare is pure look )) it's don't even ballanced. Full of cracks in the tread. I'll drive only on it if I'm reeealy stuck.. few miles...
Old Jun 9, 2021 | 07:05 PM
Look? Sensible! Granny drive if you need to use it. My AT's will still roll as low as 0-psi if needed! I've never lost air in the tires on the ground, no need to carry that extra weight from the spare/mount!
Old Jun 9, 2021 | 08:01 PM
UcraDen's Avatar
Well, I keep 40psi just in case... but yes.. totally granny style, especially if had to be mounted in front... no highway
Old Jun 9, 2021 | 08:04 PM
UcraDen's Avatar
underneath the paint, the spare all eaten with oxide
Old Jun 10, 2021 | 10:29 AM
You may have issues, H3s did not like early LED tail lights because they give a lower voltage feedback to the BCM than what is programmed in as expected from incandescent. They may not have any problem if they have enough draw from multiple lights or a built in resistor?
Kudos!
Old Jun 10, 2021 | 10:38 AM
UcraDen's Avatar
well, the assembly been made in 2018, so i guess i should be fix all issues.. also behind it has a service door with bunch of resistors soudred there.. didn't took the picture... but so far it seems to be working. we will see. anyways now ill put it on the lift to work with some issues. also more cosmetics, more lights and new radio. since its my winter car, i driving now my mustang and my harley, so h3 ill start using a lot in nowember.
btw- like many others i have issue with passlock bull****.. been thinking to buy new assembly from rockauto. but i wonder if the vehicle can be programmed to disable that option for good?
Old Jun 10, 2021 | 01:58 PM
yes it can be programmed to remove passlock. you need efi live or hp tuners.
Old Jun 10, 2021 | 05:55 PM
UcraDen's Avatar
Sorry, can you be more.. errg.. I just didn't understand nothing at all
