HyperTech programmer for 3.7!!
Old Aug 15, 2012 | 09:54 PM
Xlr8n's Avatar
Default HyperTech programmer for 3.7!!
I lifted this info from another forum, but if accurate it's good news.
Hypertech now seems to be offering a programmer with some nice adjustable features. An extra 16 hp- 22 TQ on regular grade gas. Looks like it'll run about $370.
They currently list it for only the 3.7 and only 2008 and newer. Might be worth a phone call to clarify and confirm. The model # looks to cover a boatload of GM vehicles.
http://www.hypertech.com/
They have a fully adjustable model or a cheaper one that just gives the same HP and TQ gains with no other adjustability.
It will be a big help to those with larger tires as the shift points are adjustable for each gear.
Adjustable Features
  • 1-2 Shift Point -500 to +500 RPM
  • Shift Firmness 25%, 50%, 75%, & 100%
  • 2-3 Shift Point -500 to +500 RPM
  • 3-4 Shift Point -500 to +500 RPM
  • Speedometer\Odometer Correction For Tire Sizes 24-54 inches 1/4 inch increments
  • Speedometer\Odometer Correction For Gears 2.56, 2.73, 3.08, 3.23, 3.42, 3.73, 4.10, 4.56, 4.88 & 5.13
  • Top Speed Limiter 25 - 75 MPH in 5 MPH increments, 81 to 255 MPH to match speed rated tires
  • Rev Limit -500 to +500 RPM
  • Return Back To Stock
  • DTCs Read and Clear
  • Internet Updateable
Old Aug 17, 2012 | 09:21 AM
Hypertech's Avatar
I show this coverage applies to the 2008-2010 H-3 3.5L and the 2009-2010 H 3T 3.5L Hummer vehicles.
Also as you said **many other Gm applications.
GW
Hypertech Inc
Old Aug 17, 2012 | 10:19 AM
Xlr8n's Avatar
GW
Hypertech Inc
Got a quick question for you. Since this model number is listed for multiple vehicles, do all programmers with part# 32501 work for the H3 even if they are listed for one of the other applications, or do the units leave your factory tuned only for a specific vehicle? The reason I ask as all of the ones currently on ebay listed as Part# 32501 don't even list the Hummer H3 as one of the vehicles in the apps list??
Old Aug 17, 2012 | 10:20 AM
GW
Hypertech Inc
I hate to break this to you, but ..........none of the years you mention above have a 3.5L (Atlas L52). They all have the 3.7L (Atlas LLR).
Old Aug 17, 2012 | 10:43 AM
Xlr8n's Avatar
Yeah, I noticed his typo on the displacement but the Hypertech dyno chart obviously lists the correct motor .
The dyno chart shows good gains throughout the entire range of the power band.
The adjustable shift points would be very nice to have as well as being able to change any features at any time or return to stock at the touch of a button.
I'll strongly considering trying one of these out as I've had a Hypertech on a Ram truck and was pleased with the gains on the vehicle as well.
Old Aug 17, 2012 | 01:05 PM
Bunger's Avatar
What's different about the 07, 3.7L, I5 that this won't work ? ECM ?
Old Aug 17, 2012 | 01:48 PM
06 and 07 use a different PCM and have no TCM, 08+ all have Transmission Control Modules mounted next to their PCM.
Old Aug 18, 2012 | 07:46 AM
nijoma's Avatar
Default PCM for less is 149.00
Why don't you guys just tune your pcm, they have a core program with a refundable deposit so your truck is never down. It is way cheaper and I feel better than the hand held tuners. In fact I would keep your stock pcm and just buy an extra one to tune if you want to convert back to stock it would take min.'s to change out.
Old Aug 18, 2012 | 07:52 AM
nijoma's Avatar
Default Plus
Get an Airdoc intake with the tune from PCM for less with the money you save. 149.00 pcm + 155.99(5cyl) =304.99, you have a better truck and saved 65.00 if the tuner cost 170.00. My 08 Alpha with an airdoc, tune and GM performance cat back( which was on sale for 200.00 on ebay) has made my truck. Doc if I am wrong let me know. Thanks for the intake.
Old Aug 18, 2012 | 07:07 PM
Xlr8n's Avatar
I'm not familiar with the capabilities of the PCM flash. As a comparison can someone answer the following:
Does the PCM for less have have the same features as the Hypertech such as changing shift points for each gear and speedometer calibration? And can you change them at home if you change tire sizes or do you need to send it in for a reflash? and is that re-flash free?
Does the PCM for less offer internet updates as they become available?
Does the PCM for less read and clear diagnostic codes?
Can you return the program to stock for warranty work and then re-install it without purchasing another PCM?
How do you feel it's 'way better'? The Hypertech offers similar if not better HP and TQ gains and seems to have many more features and is completely plug and play??
