humming noise high pitch noise while drive or reverse
Old 09-11-2012, 07:34 PM
hulkh3's Avatar
Default humming noise high pitch noise while drive or reverse
i have a 2007 h3 base 94k on it everything works great but i noticed a high pitch humming noise. i intsalled a k&n intake and thought it was that but its not. my h3 sounds like a rich burner right now the sound only comes when i am in drive or reverse. someone told me that it might be the transmission and changing the fluid might help the sound. when i baught the h3 4 months ago the sound was not there only after i isntaled the intake..any help is greatly appericated thank you in advance ..
Old 09-11-2012, 10:36 PM
2wheelmonster's Avatar
sounds like you have an air leak somewhere, did you try putting the stock air intake back on to see if it goes away?
Old 09-12-2012, 08:02 AM
hulkh3's Avatar
yes i put in back on and the sound is stll there. i thought it might be a ir leak but when the h3 is in park and i push the gas i dont here it only when in drive or reverese and there is no grinding noise just a high pitch noise when accerlating
Y2KH1
04-21-2014 06:21 PM
hulkh3
09-14-2012 07:46 AM
jco
08-29-2012 07:35 AM
HUUMHER07
05-26-2010 08:53 AM
Quick Reply: humming noise high pitch noise while drive or reverse
