Hummer H3 ? Tires How big on stock ride
How big over all tire diameter has been put on a stock off supention / NO LIFT ? 36" ... ? could I squeeze in a 38" with out blowing off da fenders!
RE: Hummer H3 ? Tires How big on stock ride
ORIGINAL: edmonton ab "big deel a mis speled word", you got the mesage and point! stop nerding it up and bull****ing up the site with comintary. or I will run you over with my 46" boggers Once again you have posted something that has been beat to death in numerous threads. Do a search and you will find all of the information you need about tires. |
35's are the largest for stock suspension.
All greetings, from Russia vs Love! ))
Whether correctly I understand 35`=295/75/16 and it is greatest possible size of tires on stock 16`disks with a stock suspension? Recommend, please, as much as possible wide tires on stock for city conditions It would be simply wonderful to look at a photo of your offer! ;) Thanks! What variants will approach?! 1)285/75QR16E 2)285/75RR16D 3)295/75RR16D 4)305/70R16D |
Nyet..
a 275 x 75 x 16 = 32.2 inches The H3 without suspension adjustments, will accomodate up to 305 x 70 x 16 Play around with this TIRE CALCULATOR |
ORIGINAL: edmonton ab could I squeeze in a 38" with out blowing off da fenders! |
I am sorry, but what maximal size for 16/75/? and 16/70/?
in STOCK |
Whether all will be ok if I shall put 295/75/16 on FULL STOCK? And what pressure in such tire should be (BF All-terrain T/A)?
http://www.bfgoodrichtires.com/image...ain-t-a-ko.jpg |
a 295/75/16 is basically a 33 inch tire....we have said 23,000 times now that a 35" tire will fit with no mods....soooooooo......a 33" tire will fit and is actually what comes stock on an adventure. As far as tire pressure, follow the manufactureres suggested pressure as listed on the tires sidewall.
Many thanks for your answer!! Long waited and could not find a photo with the greatest possible tires anywhere (NO MODS).
Last question from your permission ))) Please do not become angry!! :)) So, what greatest possible size can be put on stock without any mods?? With a picture it would be absolutely wonderful! thanks once again |
| All times are GMT -5. The time now is 09:48 PM. |
