how to reset PCM
I've read on this forum that removing power from the PCM is not enough to reset it. So then how is it done? Is it possible to get the adaptive learning values back to default?
Originally Posted by Justinh
(Post 404425)
0V where, across the battery cables?
(Post 404430)
0.00v @25https://cimg9.ibsrv.net/gimg/www.hum...dc77c82128.jpg |
Thanks.
You cannot "reset" a PCM. You can reboot it, but it will retain the last 300 ignition cycles, power or no power.
The only way to change what is in the PCM flash based memory is to over wright it. |
| All times are GMT -5. The time now is 09:56 AM. |
