Hoping to get answers
Hi. I need to resurrect this thread because, after a month, the Stab Sys Traction Failed Service message re-appeared. If letting you know of these codes will help determine why the message re-appears, here they are: P0327, P0128, C0276, C0327. Can someone help in identifying what these codes mean and if any of these are directly related to the Stab Sys... message?
Many thanks for your kind response. This Stab Sys... message is really an annoyance.
It's a shot in the dark here....but that was my issue. I would say it's tied to the ABS system.
Once a mechanic said my torsion bar bushings need replacing, i told him to show me and it turned out he was talking about the lower control arm bushing (where the torsion bar ends)
Is your steering out of alignment btw? I read somewhere that if your steering angle is off by alot the truck will give a code.
p0327 Knock sensor (KS) 1, bank 1 -low input
p0128 etc or T-stat
C0276 info....
C0276 Engine Code Meaning - C0276 Engine Trouble Code - How To Fix C0276 | EngineCodes.net
C0327 code info....
https://www.google.com/search?newwin....0.0uxE_hA4Dh0
Have your replaced the battery, bat connectors, checked bat pos/neg for solid connections?
I posted back awhile ago a p0128 was your t-stat/etc. did you not replace them?
p0128 etc or T-stat
C0276 info....
C0327 code info....
Obioban
19
09-06-2011 06:10 PM
dave85c4
03-15-2006 05:24 PM
