HELP with a possible oil overfill!
Ok, I just finished changing the oil on my 08 H3 per the awsome instructions with pics on here. I did the change with 6 quarts of valvoline full synthetic, but when i read the dipstick, it is so clear that I can't tell if there is not enough oil, or the L-F indicator is completely covered. Ithink, and am concerened withitbeing covered, so I poured all the old oil back into the containers to see if 6 quarts came out. It looks like only 5 1/2 came out, but I also had a spill from the oil shooting out to the side when I took the drain plug out (i did not read the addition comments section, or i would have know that). It also doesn't help that I am doing this at night and my only source of light is a halogen construction light. Any thoughts on this causing any serious damage? The wife is leaving for work before the sun comes up, and if I tell her she can't drive it, she may run me over with it. J/k, but she does love it that much.
RE: HELP with a possible oil overfill!
You should be fine. Start the engine let it run for a minute then shut it off remove the dipstick clean it off and reinsert it and then check it, you should be able to get a reading or at least see some air bubbles on the dipstick.
rhill20
07-01-2013 12:23 PM
rodney960
12-15-2008 03:56 PM
hummer07
11-18-2008 10:46 AM
6qts, car, damage, engine, fill, h3, harm, high, hummer, level, oil, oldsmobile, overfill, overfilled, overfilling, transmission
