Help H3 key wont turn car Won't to in gear
Quick question guys, I have a 2006 hummer h3. My battery died earlier I recharged it. Now I have a problem, my key wont turn, and i can't press the button on the shifter to put it in gear. I'm a bit fustrated. I can't go to the dealer any suggestions on how to fix this? I already tried wiggling the steering wheel side to side and disconnected the battery. Any one dealt with this?
bypass the park lock solenoid by doing the following: pop the cover off of the shifter console area. look on the right hand side for a button looking thing. put your parking break on. push the button and shift it into neutral. see if your key will turn then.
you could also check your bcm connection - I have ignition problems and they go away if i wiggle the black connector on the bcm
just my two cents
When I said "easy" I meant "free." Batteries cost money - popping that cover off and putting it into neutral takes 30 seconds.
The reason I'm thinking it's not just a dead battery is because the key won't turn at all. From my limited experience with H3s the key will still turn when the battery is dead - it just won't let you pull the key back out.
nncanfarelli
08-04-2019 09:27 PM
Alex2012
07-12-2012 06:22 PM
