Having shifting problems
Came to the site looking for answers and found this post. I’m having similar issues. I have a 08 h3 with 146K. I did transmission and filter change around 100k. I only have problems up shifting from 3 to 4, according to the diagram from the earlier post. I feel a small vibration and sometimes a jerk as it shifts. Sometimes the jerk is pronounce and sometimes it’s not. I can say it starts at around 45mph and stops when it shifts around 50. Any thoughts or help is appreciate as I want my hummer to last a long time!
TIA
TIA
TIA
TIA
Add a can of seafoam to the transmission, make sure to check fluid level at operating temp, drive for awhile, then get a transmission fluid flush.
https://seafoamsales.com/product/tra...uid-treatment/
Also monitor the color of the trans fluid on a paper towel, as I posted above. Seafoam is a great cleaner, then flush it out. I've corrected many trans shifting issues this way. GL
So, I'm back. My transmission fluid seem fine as it was still red in color. I took your advice and put some seafoam in and flush the fluid. Also, changed out the filter while I was there. It seemed better since then and would rarely jerk or vibrate during shifting. Yesterday as I was during, felt the vibration again and got the CEL. I'm now throwing 2 codes. A P0700 Transmission Cntrl system malfunction and the other is P0741 Torque Converter Ckt Perf/Stuck Off. Any thoughts? I read it may be 2 solenoids in the transmission, the transmission control module, or the torque converter. Any help on where to start?
Thanks All!
Thanks All!
daiglesbagels
08-31-2014 08:57 AM
Rusty_03
09-04-2012 02:45 PM
