Handling mods
1 Attachment(s)
Ok,..so I'm not into rock crawling and stuff,...I use my yeallow station wagon for commuting to work and hauling stuff from Home Depot and Sams' Club.
Anyway,..I like sports cars (have one) and hate it when a car pushes terribly in a turn. So I set about to make a few improvements in the H3s' street drivability. First mod was to order the Ground Force lowering kit. Mid $300 range,..and came with tapered 3" lowering blocks for the rear, longer "U" bolts,..better rear shocks (less compression dampening I believe), and better designed spring plates, so the shock doesn't ride below the bottom of the leaf spring. Here's what the kit contained; Attachment 20790 And a pic of the rear shock perches/spring plates; http://i177.photobucket.com/albums/w...kitplatesf.jpg After doing the 30 minute lowering job,.. here's pics of the result. Stock height. http://i177.photobucket.com/albums/w...itbefore-1.jpg 1" front drop,...3" rear drop. http://i177.photobucket.com/albums/w...tafterpost.jpg Now,..this admitedly this looked a tad odd. Even thoguh the wheel gaps were perfectly even,..there is an optical illusion that the rear is low. So I bought some 2" spring spacers and used them last winter,..and this summer I reinstalled the 3" ones and lowered the front a 1/3" more than in the above "after" pic. Looks very normal now,..and drives great. Maybe in a day or so I'll replace the after pic with what it looks like currently. Next was to lessen the front push (where the front tires howl incessently in any turn). I used a 2 pronged approach, employing the same stuff I use when I track my sports car. One was to add some front negative camber. Idialed in-1.34 degrees. Stock is zero,...but not only does this result in lousy handling,...the front tires also showed excessive wear and cupping on the outside. So some negative camber would not only impove handling,..it would also increase tire life. Step 2 was to stiffen the rear swaybar. I know thatHellwig (and maybe others) make a stiffer one,..and includes stiffer bushings for the front http://www.teakatoys.com/Hummer_H3_S..._p/hw-7682.htm for $264,..but this is a lease and I don't want to add too many aftermarket parts or spend too much money. So I decided to modify the stock bar so as to make it adjustable. The stock bar is solid and pinched at the end. I added some weld to the top and bottom of each end an inch or two from the ends,..and then ground that part of the round bar flat. All this to extend the flat and wide area where the endlinks attach. Then I drilled a new set of holes an inch inboard of the origionals,..and hit them with some black spray paint. The endlinks are actually closer to vertical than before. http://i177.photobucket.com/albums/w...aymodafter.jpg If I'd though about it a year ago,..I might have ordered up a set of 18" rims from Tire Rack with some bridgestone Dueller LT (Not the A/T that the H3x comes with). But my lease is up in 10 months,..so this is probably all I'll do. I'll sell the lowering package before then and put the rear endlinks back in their origional holes. If I had it to do over,...I'd make the second set of rear endlink holes 1.4" inboard, and maybe run -1 degree of front camber. It'sgreat now,...but that might suit more H3 owners better. No calculators,..just trial and error. This pic addeda month and a halfafter start of topic, so the coments below don't include |
RE: Handling mods
Sweet!!
I think Vader may be interested in this!!! |
RE: Handling mods
nice.there are quite a few out there that wouldnt mind a lowered look.......and that doesnt seem to be a bad price
RE: Handling mods
You can lower it with just spring spacers and longer "U" bolts. Total cost should be $30.
Stock "U" bolts are 3 5/8" ID and 7.25" long. So you'd add your desired drop to the 7.25" length. Here's some that are 3 5/8" x 10", so they would be good for a 2.75" drop (probably for a 3" too). You can just cut them down to the required length if you don't like having the extra threads hang down. Note,..that after 2" you need to use tapered blocks to keep the pinon angle in check. $12.50 http://www.ruffstuffspecialties.com/...-10-p-215.html Here's some lowering blocks $14.76 a pair. http://www.gcustoms.com/product_info...oducts_id/264/ So to do a 2" rear drop and a 1/2" front drop would run about $28.00 This would be a good option for those simply looking to level their cars. A 1" drop in the back and a 1/2" lift in the front would work great also,...and be much better for the suspension and front axles / CV joints than simply trying to crank the front up 2". The Ground Force kit also gave a better ride with the better designed shocks. Less comp dampening and possibly a tad more rebound makes it less bouncy. I'd think everyone would like the car better with a 1.5" rear drop, but I haven't found 1.5" blocks. So 1" rear drrop with 1/2" lift in front or 2" drop in back with a 1/2" drop in front seems the best options. |
RE: Handling mods
My brother shorty may have collapsed on the ground, unable to type after reading this thread...so I will do it for him....
RE: Handling mods
i hit my head hard on the floor - now that you've done all that work, does it handle like a porsche?i can't see the point in all that just to make it more like a car - why not just buy a car? :eek:
RE: Handling mods
ORIGINAL: shortbus i hit my head hard on the floor - now that you've done all that work, does it handle like a porsche?i can't see the point in all that just to make it more like a car - why not just buy a car? :eek: Yes it does handle dramatically better now. Not like a Porsche,..but probably like an Impalla SS (which I humiliated on a freeway cloverleaf last night). |
RE: Handling mods
1 Attachment(s)
Wel now, this is interesting. I would cut you all the slack in the world on whatever you want to do with your Hummer. You paid for it, if you want to lower it, cool with me. I have no problems with street Hummers for pounding pavement. Not my style, but that doesn't matter. There are more off roaders on this site than pavement pounders, but everybody is equally welcome. :)
The Suburu thing, and from a Detroiter, I'm gonna try super hard to keep from sharing my opinionsabout jap crap. ;) Got rice? Attachment 20788:D |
RE: Handling mods
Why did you get an H3 if you want a sports car?
RE: Handling mods
ORIGINAL: Desert Dan Why did you get an H3 if you want a sports car? And I have the H3 is for when It's really cold out (remote start) and for when I need to haul concrete, mini-fridges, plywood (on roof) etc. It's also my loaner car when a friend needs to borrow something. A friend of mine turbo'd his Cobalt SS and used it for 3 weeks recently. I really like the new Ford Edge too, but the Flex will have more room for hauling junk. I'll have to check it out when it hits showrooms. I had pulled the rear seats out of the H3 to try to get more cargo room. It's tiny inside,..but does have the required 32" rear opening height I need for mini-fridges (I own a small hotel). I'd done these mods a year and a half ago. I'd just thought I'd post them somewhere for others amusement / benefit before I turned the car in. There's opnly about a 30% chance I'll get another one. Some visitors to this site may want usable armrests,...rearward vision or descent handling. For those rare people,..heres what I did. True most people on this board probably go out of their way to drive off-road,..but 9 out of 10 H3 owners use them like a minivan. Some of them may happen along this site one day. |
