A H3X with Squeaks and Moans!!
Old Oct 18, 2007 | 06:01 PM
mh307's Avatar
Default RE: A H3X with Squeaks and Moans!!
Hmm...sometimes my springs tend to sqeak when im parked. Sorry, couldn't resist.
Old Oct 18, 2007 | 06:06 PM
pgaduane's Avatar
if the hummer is a rockin don't bother knockin......[:-]
Old Oct 19, 2007 | 10:51 AM
buzzwohl's Avatar
I hope I don't have to disassemble the spring packs. I was able to move one spacer back in place using a pry bar. Will try and take some weight off springs and get the upper pads in place using a long pry bar with a couple of us prying away. I'll let you know if this works.
Old Oct 19, 2007 | 11:06 AM
Have a line up punch handy for reassembly if you take out the spring pin, and be carefull.
Old Oct 19, 2007 | 03:04 PM
H3 Xman's Avatar
I don't have that problem. Maybe the wheel cover isn't tight onto the rear door.
Old Oct 26, 2007 | 11:58 AM
buzzwohl's Avatar
Have yet to receive all the leaf pads. But did replace two of the upper pads on the driver's side without removing theleaf packs. I placed the jack under thefront shackle and lifted the vehicle until the tire was off the ground then used a large screw driver to pry the leafs apart and slid in the new pads inwith a light coat of silicon grease. Did have to trim the edges of the pads button so the new pad buttons could be inserted into the button hole in the spring.Hopefully they will stay in place.squeak free now
Old Oct 26, 2007 | 05:14 PM
JDEORTA's Avatar
Mine squeeks a lot too, except when its muddy. Buzzwohl thanks for the info on the teflon pads
Old Oct 28, 2007 | 02:03 PM
buzzwohl's Avatar
Anytime. Mud is a good lubricant on leafs when its wet. One of the problems with the factory pads is they are round. That rounded edge takes a lot of pounding and wears flat so the spring can overide it and make contact with the next leaf. Rectangular replacements (2 1/2" width) fit perfect and should have more of the leaf tension evenly distributed across it.
Old Oct 29, 2007 | 07:14 AM
D VADER's Avatar
So Buzz your squeaks are gone? Where did you get the teflon pads?
Old Nov 2, 2007 | 02:37 PM
JDEORTA's Avatar
I cleaned and sprayed mine with Rustoeum Hammer head finish and all the squeeks are gone I know its just a temp fix but the squeeking was driving me crazy.
