06 h3 clicking
06 h3 clicking
Hi guys i am new to this site. I changed my front and back brakes and now i hear a clicking sound in front. I have checked everything out and i cant figure it out when i push on the brakes it stops when i drive it clicks. If you can help me with this problem that would be great. Thanks
MOVED to the H3 section for you (where questions about H3s should be).
Welcome.
Real hard to diagnose "click" and other noises by description alone, I usually do not bother, but since I am here anyways. The most obvious possible cause is that you did not put the brake pad spring clips back on correctly (yes they can go in/on backwards or actually upside down) and they are allowing the pads to not back off far enough after braking so they intermittently touch the rotors and rattle/click.
They are supposed to go in like this:
Welcome.
IHNEVELS
09-14-2013 05:18 PM
