H3 Wheel Well Liner removal
Old 02-15-2018, 09:29 AM
Aaajaws's Avatar
Talking H3 Wheel Well Liner removal
I know somebody is gonna yell at me but. I need to take my driver side wheel well liner out to get to the knock sensor and the side marker light to replace the bulb. Things are cold up here n New England and plastic has a tendency to crack just by looking at it. So before I break something LIKE I ALWAYS DO what tool is recommended to remove the center pin of the black plastic push pin I will call it looks like 7 of these holding wheel well in ? All of the searches I have found said "just remove it" although picture links were showing up none were visible. Was thinking the forked interior tool ??
oh bulb part number if handy too thanks I think its a 194 bulb but want to put LED to be done with that thinking they are T10 ?
Thanks in advance
Jaws
Old 02-15-2018, 10:52 AM
RKSmith163's Avatar
There are a couple of screws involved also.
Old 02-15-2018, 11:09 AM
Buy a Pull tool like this it will make your life easy.
Buy some more Fender Liner Clip Push-Type Fasteners/Retainers 11589292 for GMC/GM/CHEVY/HUMMER while you are at it. 100pcs for $6!
You WILL break some and they are so cheap and you won't care about breaking all of them. Give some to your buddy's too!
Amazon Amazon
There is also a bolt at the front near the frame and radiator and depending on your rig there may be 1 bolt and 2 screws at the rear holding the mud deflector on.
Park it indoors inf possible overnight.
Old 02-15-2018, 11:15 AM
Aaajaws's Avatar
Just ordered them on EBay 11589292 Thanks for the tip. My garage just as cold as outside lol and jammed with big boy toys.
Jaws
Old 02-15-2018, 01:54 PM
Happy Hummer's Avatar
as always great suggestions... lol!
I'd recommend a good choice of expletives in reserve, especially if it is cold and icy/snowy.
Fact is I did four of these liners on two H3 in spring of 2017 and it was a long slow process to get them out. Anything that can corrode / rust did and most of the plastic retaining snaps just fell apart from all the salt and crap from winter. The light bulbs for the side markers were a pill to say the least.
Old 02-15-2018, 03:40 PM
classic87's Avatar
I just went thru replacing all of mine last week... they fit so much tighter and less rattles with new fastners.
Old 02-16-2018, 06:26 AM
hichamaziz's Avatar
i find that thread useful thank you o lof of.
Old 02-16-2018, 09:08 AM
T was able to pull the fender liner on each side (had to replace the passenger side due to a CB Photo Chipmunk Trail incident) without breaking a single clip and reused them all.
Old 02-27-2018, 01:36 PM
Aaajaws's Avatar
Default Job Done
I ordered a T10 LED bulb but was to tall in the socket by 1/8" so put back a 194 bulb.
8 Clips an Job complete.
redneckhoosier
09-05-2013 09:55 PM
chasetexas22
12-22-2011 11:24 AM
Gunner_45
08-16-2007 12:44 AM
HummBob
37
03-20-2007 07:22 PM
Quick Reply: H3 Wheel Well Liner removal
