1 Attachment(s)
Here is a pic of my 06 with leveling kit 20" xd monsters with 35x12.50 nitto trail grapplers
Originally Posted by ar_h3
(Post 242541)
Do you know if your wheel's are 20x8.5" or 20x10" Thanks Jeff |
No offense, but it looks like a Tonka Toy Truck
They are 20x10 they tuck in very nicely, the only place it rubs is the front corner of fender lining. this can be fixed real easy with a pair of sissors. BTW absolutely no offence taken, to each his own buddy.
ar_h3...
...You say you have 20 x 10 ....according to XD they only come in -12 offset...is this correct? Do you have 20 x 10 with 35"x12.5" tires and -12mm offset....? Can you post more pics? I would like to see how far they stick out the fenders? Can you explain more where they scrub on the fender lining? Appreciate if you could give some more info... |
2 Attachment(s)
yes 20x10 with 35x12.5, i got them used with 200 miles on them im not sure the off set. but if the website says that the 20x10s ARE -12mm offset then i guess that is what these are. it has been snowing here in central Arkansas so its kinda hard to see the pics because its so bright outside, but hope this helps you
Thanks for the info... I know in the rockstar 775 you can only install the 20x8.5" because it has a -10 off set and backspacing is 6", now if you go with the rockstar 775 wheel in 20x10" it has a -24 offset and backspacing is 5" so your wheel will stick out 1" by starting off then the wheel is 10" so this will make the weel's stick out to mutch with the rockstar 20x10"...... Now if you go witht the xd monsters wheels 20x10" the off set is -12 and the back spacing is 6" so this wheel will fit better on the hummer...
so all come down to this if you go with rockstar wheel you need 20x8.5" abd if you go with xd monster you need 20x10"... now this sizing is for installing 35" tire on hummer h3. Thanks Jeff |
(Post 242719)
They answered all my questions. The scrubbing....there maybe some work with the heat gun could already help. Ur wheels and rims stick out 1-2" as it looks on the photo...that would fit also with the offest of -12....this is exactly what I need with the factory fender flares. |
bump :)
my 20x8.5 rockstars just came in, I'm pretty excited. Now I just need to decide on what tires to get..
| All times are GMT -5. The time now is 09:54 AM. |
