H3 help!!!!
Could that still be the issue even though I can switch to 4 High lock and 4 Low lock? I can switch to those and drive around my yard.
Also I forgot to add that the CV joint on my front drive shaft was messed up. The boot was ripped off and slung into my under carriage. Believe it or not it was still stuck behind a piece of metal and I was able to grab it out. I replaced that part but still had the issue.
I can't make out your picture. Looks like a pile of dogshlt? Use a stick magnet and see if anything attracts to it. If all good, check the fluid on the transfer case. Btw get some fresh fluid in the front diff. I recommend royal purple maxgear.
Lauren, I thought it was your wife's H3, and why did you hijack this thread?
help
I wonder if that was the result of a stabilitrac shut down causing a low power mode while going down the highway? That happened to me going about 30 mph. Suddenly lost power and rev than i couldn't go more then 10 mph. No damage just cleaning the aftermath of a rogue mouse ate half my air filter.
