H3 acuator motor
Unclip electrical connector. Two bolts, remove them, remove the actuator (#12). Pull the T Case seal (#11), put in fresh seal, re-install new actuator with the two bolts.
You can test for power at the truck side connector, some have had corroded connectors, frayed or broken wires give them problems.
A squared shaft comes out of the T Case through the seal and goes into the actuator. All the actuator does is turn the shaft to shift. If they get real wet.... like when you get stuck in deep water and muck for 15 minutes +.... they puke.
Ken06H3
09-04-2007 08:32 PM
studio theater
05-23-2007 07:51 PM
