H3 5 speed shift knob, need help !!
1 Attachment(s)
Hello, guys I'm picking up 2007 H3 hopefully tomorrow and I need the trim piece for the top of the shift knob that has the shift pattern on it...
If you look at the pic below you can see the stick shifter, shift knob, and boot are all one unit....I would really like to avoid having to buy that whole unit if possible.. :o I just need that insert for the top of the shift knob.. PM me if you have one or know of one please.. Thanks ! |
Part found
Another H3 owner from a different forum stepped up and gave me one.. :)
manual shifter decal
[QUOTE=Ground Pounder;304994]Another H3 owner from a different forum stepped up and gave me one.. :)
Please tell me where and how you found one. Mine is also trashed and I want to replace it without having to buy the entire shift lever. You can send your reply to my email if you like. alangoodgsm@aol.com |
5 speed manual shifter knob pattern is worn off
the top of my 5 speed manual shifter that shows the shift pattern is all flaked off and looks bad. Short of installing the new shifter , is there a decal that can be place over the worn out one?
shift knob decal 5 speed manual
Ground Pounder, pls tell me how to get in touch with the member who hooked you up with a new shift knob decal.
[QUOTE=alphamale60;395057]
Originally Posted by Ground Pounder
(Post 304994)
Originally Posted by alphamale60
(Post 395418)
Google it. |
