Got the H3t Back
Got the H3t Back
Well a bunch of work has been done but the ''Service Traction Control'' still showing but driving it with the traction off it is running great but I did notice with the light switch set at Auto the headlights are not coming on. Could this be a clue? They do work when switched to on. Anyway gonna drive the crap out of it this weekend and see where it takes me!
P0300 is random misfire. The others I can try to look up tomorrow.
clean throttle body. Clean mass airflow sensor. Replace spark plugs with AC Delco oem. Replace air filter. Make sure air resonator box hose isn't dry rotten.
Thank you for your reply Air flow sensor was cleaned then replaced The truck is not misfiring even though the code shows. If fact the truck is not doing anything the 4 codes show it doing. Another member suggested it might be a bad instrument cluster. Your thoughts?
GEEZ another problem......... I have been driving the truck and it has been doing good with check engine light on and service Traction Control warning. I turn off the Traction Control while driving with the button. Last night while accelerating to get on highway not much power and the the REDUCED POWER indicator shows and check engine light starts flashing. I was able to limp home doing 45 mph, Now what should I be looking for? Using the search feature I see clean throttle body, PCM, replace spark plugs & air box. Does it ever stop with these trucks?
If the CEL was flashing, there should be a misfire code in memory (P0301 would indicate misfire on cylinder number 1, for example). Clear the code, swap the coil from whichever cylinder was misfiring to another cylinder. Go for another drive and see if the misfire moves to the cylinder where you mounted the suspect coil. If the misfire moves with the coil, replace that coil. If not, post back and we can go from there. Which engine do you have?
Thank you DJB when I went to start truck today after posting the above it would not start completely dead and security lock indicator showed on dash finally got it to start how I do not know had it scanned and only codes showing were P0856 Traction Control Torque Request & P2432 Air Induction low voltage I did notice the positive factory battery terminal was loose also. Truck is semi driving normal now after a few mile test dirive. Thanks for the help & info
