GBCM delete
I just bought an 07 H3 adventure. Have most of the bugs figured out except one. P.O. deleted the Generator Battery Control Module (GCBM), not body control module (BCM) as so many think. The alternator is charging. Battery is new but the battery light is on. I can find references to deleting GCBM but cannot find out if that's the cause of my light being on or if it can be turned off without replacing the the module. Any suggestions?
Sadly, anytime p.o.'s get into that much modifications it's hard to know what they did or why.
Stab in the dark possibly the PCM was no longer able to regulate (because if memory serves me correctly GM moved the regulator into the main brain) so they decided to bypass the gbcm so to be able to still have a charging system function without the expensive PCM/ECM brain change. Jeep forum members do this frequently on older Cherokee. If it is charging and the truck is running just leave it. On the other hand if it will keep you from passing state inspections you may need to undo all the stuff done. |
(Post 357864)
What kind of Battery Terminal Connectors are you using?
Right now just the lead clampdown generics
Interesting. Grabbed an sarvc at junkyard. Plugged it in and the hummer will not start. Good for theft control bad for driving.
