Fuel pump fitting rotted.
Fuel Pump assy, fitting rotted out at the soldered fitting to the housing. Seems to be common, so I tapped the fitting with a 3/8 16 tap. Now I just have to rustle up some fittings & keep this baby for a spare. These are'nt cheap. Good redneck ingenuity.
MOVED this for you from the H3 FAQ, because it is not, and at the top of that section it states Please DO NOT POST IN THIS SECTION.
Good tip. |
Good idea. It would be great to see a pic of it.
https://cimg0.ibsrv.net/gimg/www.hum...603d910579.jpg
I tapped & threaded the port & plan on keeping it for a spare. Pump works fine. |
