Fuel cap light?
Old 06-06-2012, 05:49 PM
scuba namena's Avatar
stopped after work to have the codes read. p0455, and p0442. so i guess they were related? i replaced the fuel cap. the old one had a tiny nick in the seal. had the codes cleared. drove 40 miles home. so far no code or light.
Old 06-08-2012, 07:31 AM
WannaScoopaDis's Avatar
Hope it works. Keep us updated.
Old 06-08-2012, 10:10 PM
no problems since last posted. knock on wood. seems to have worked. thanks all.
Old 06-08-2012, 10:42 PM
Thanks for posting back up that it is solved. So many just ask for help then don't tell us if it worked or not. Helps the next guy who has the same or similar issue.
Old 06-11-2012, 07:27 AM
Thumbs up
Thanks for the update
Old 06-11-2012, 02:56 PM
unfortunatly...
warning light poped back up Saturday and again today on the way in to work. not a CEL this time. just the "FUEL CAP" warning above the odomiter. not sure where to go from here???
Old 06-12-2012, 08:24 AM
CEL on the way to work today. ill stop after work and have the code read.
Old 06-14-2012, 08:11 AM
stopped and had the code read last night. it read P0442 (small leak). so any thoughts about my next step? should i take it to the shop? smoke test? thanks all!
Old 06-14-2012, 08:16 AM
Since you did the gas cap already, know you should be looking at the EVAP system. Start with the connection at the top front side of the TB and follow the hoses to the canister etc....
Good luck.
Old 06-15-2012, 11:33 AM
Thanks Doc.
Quick Reply: Fuel cap light?
