Front Hub Bearings
Old 05-04-2019, 09:33 PM
wongsol's Avatar
Default Front Hub Bearings
I put a lot of miles on my H3 and have replaced each front hub at least twice. I DO buy budget hub assemblies and I realize the premium hubs with better bearings might be worth the price. I was wondering if these hubs are rebuildable, meaning, can I press out the bearings and replace THOSE with premium bearings instead of replacing the whole assembly.
TIA
Old 05-05-2019, 07:21 PM
You will have to spend money on the bearings, seals, and you need the proper equipment to replace, and you also need to make sure there is no damage to the hub.
I think you need mental help, just like this guy needs, for a $50.00 brand new hub replacement:
Old 05-05-2019, 11:18 PM
wongsol's Avatar
I work in a shop that is equipped....
Was that a necessary comment? Good hubs aren't cheap, I already said that I was buying "budget" minded hubs.....
Old 05-06-2019, 01:20 AM
happythree's Avatar
you must enjoy the work. seriously,i did timken on a wj jeep and it was not fun.got 146000 on originals.
if its around at 300000 i wont be. timken at $150 a pair is cheap...
Old 05-06-2019, 07:14 AM
wongsol's Avatar
I do like the work (motorcycle mechanic) and I do most of my own work sans transmission rebuilds. I get the fact that the cost for a replacement hub is inexpensive. I will replace the bad hub and keep it and play around with it instead of tossing it in the scrap metal bin at work. I'll update the members if I'm successful.
Old 05-06-2019, 08:56 AM
talusfan's Avatar
Buy oem hubs, yes they are more expensive or you can keep replacing cheap hubs until you get tired of it.
Old 05-06-2019, 11:39 AM
atvspeed4's Avatar
And PLEASE use a damn torque wrench on the axle nut...
Not using one will destroy a hub prematurely no question.
Old 05-06-2019, 11:54 AM
happythree's Avatar
why is that?
Old 05-06-2019, 12:37 PM
H3Luxembourg's Avatar
Just get OEMs or good aftermarket hubs, no junk, it's for your security ! I think 200 or 250 bucks are not too much to spend in life for a secure drive.
Old 05-06-2019, 02:28 PM
wongsol's Avatar
https://www.hummerforums.com/forum/h...pecs-h3-32901/
Quick Reply: Front Hub Bearings
