-   Hummer H3 (https://www.hummerforums.com/forum/hummer-h3-17/)
-   -   Front end rattle - solved (https://www.hummerforums.com/forum/hummer-h3-17/front-end-rattle-solved-9623/)
haiminger Jan 24, 2008 06:51 AM
Today I drove my truck to the shop, and when it was up on the lift, I saw immediately that the rubber on the drive shaft (the far end of the drive shaft - going to the back wheels) is totally messed up.
The finished replacing the drives haft about one hour ago, and all the rattling is 100% gone.
This is the second time the drive shaft has been replaced, and I've done only 19,000Km.
Is there a know issue with this?
Thanks in advance for your help
Haim
Trey124 Jan 24, 2008 08:28 AM
RE: Front end rattle - solved
I haven't seen this topic on the forum.
haiminger Jan 24, 2008 08:51 AM
ORIGINAL: Trey124
It's not allways good to be the first one with a problem :(
alrock Jan 24, 2008 09:00 AM
Haven't seen/heard that. I've thrashed the u-joint on the front prop shaft, on the end towards the front and away from the transfer case.
importkiller Jan 24, 2008 09:41 AM
I would just get it fixed with aftermarket u-joints...stockers suck.
Doc Olds Jan 24, 2008 11:48 AM
Haim: It's your wheelin. [8D] :D Glad it is fix up for ya, you will know what to look for next time. [&o]
