Front differential
Months ago my right rront axle was replaced weeks later the car didn't move anymore and the shop said the front differential had to be replaced or rebuilded now I see the car when you go on reverse and turn to the right is kike stuck When you move ahead it move without problems what is it? |
Need to remove cover and inspect. Sounds like spider gear
Rebuild
do you really think they rebuilt the differental? When the truck got stuck and you move forward you can listen a strong noise like “clsmp” and then it moves smoothly yes like a gear out of position any posibility the axle gear is a different relation ? thanks |
"clsmp"? Try as I might, I cannot imagine that sound.;)
Simple, take it back to the shop that rebuilt the diff.
Tell them the symptoms and have them fix what they didn't the first time. |
Might also be that your transfercase is stuck in 4Hi lock. Even if your indicator light is showing its in AWD, a badly worn shifter fork can allow it to hop ranges. This has happened to two of my H3 and on another hummer forum it lead to a guy snapping his CV shafts when turning in a parking lot.
sorry for this long delay
I had to be out of the country for months, retaking the issue with my front differential, how can I isolate the problem between the diff or the transfer case? I'm thinking to replace my diff buying a used one in ebay, is that a good idea? I don't want to be in front of the same problem in months, if I replace it, is something that I can do by myself?, is it too heavy? best regards |
Originally Posted by Julio A Lopez
(Post 356810)
I had to be out of the country for months, retaking the issue with my front differential, how can I isolate the problem between the diff or the transfer case? I'm thinking to replace my diff buying a used one in ebay, is that a good idea? I don't want to be in front of the same problem in months, if I replace it, is something that I can do by myself?, is it too heavy? best regards You may have been gone a while, but the truck won't have many miles since they worked on it. Search for Transfer Case stuck in Hi Lock, make sure it is not. |
the only problem Doc is the shop is 200 miles away, in Sarasota, the car is in Miami
and more than a year ago |
Well that sucks. Still might be worth a call to them if you have been out of country on deployment.
Make sure the T Case is not in lock. Do some searches, but in a nut shell, shift the T Case into lock on soft surface (not dry pavement) drive a 100 feet or so, then shift to Hi, might try to back up in a safe area and turn back and forth. Then see if it feels different. Good luck. |
