few questions from the new guy
Old May 30, 2013 | 01:17 PM
Tubby's Avatar
Default few questions from the new guy
hello everyone, I am new to these boards. I have a 2007 H3 with the rough country level kit installed on it. I have a few questions. ever since i put on the level kit my front end seems alot more sloppy. Do I need to put the spacers on the shocks, or change to a different shock?
also I dont know much about wheels or tire sizes, whats the biggest, widest combination i can go with, without having a rubbing issue or need to make any modifications?
I figure these are simple questions, but Im not the most tech savy guy out there, thanks in advance for any advice
Old May 30, 2013 | 02:53 PM
sneakypigeons's Avatar
315/75r16...thats a 35" tire. you can clear that without any mods. I have that rough country level kit also. i didnt put the spacers in the shocks and i didnt use the rear shackles either. i only used the spacers for the torsion bar bolts. guess i could have saved myself $70 and used something else.
but yes your front end will feel more "sloppy". I have mine set at 23.75 " in the front. I like the way it handles. your gonna have to get longer "bump stops' for the front now cuz once you level the front the A arms are no longer in contact with them.. this helps when braking and cornering.
Old May 30, 2013 | 04:22 PM
staggs's Avatar
yes it is normal to feel a little more sloppy, basically the bump stops are an active dampening part of your suspension and rest on the control arm, by leveling it you are creating a space between them allowing for more dive and sway in the front end. You can get longer bump stops or/and get stiffer shocks, like billstein or adjustable rancho 9000's.
Also did you get an alignment after the lift? if not that would e your number one cause.
also keep in mind that with the increase of tire size come a little less feel of stability, with 35s and a 16 rim and depending on the tire you can add a lot of tire sidewall roll when you turn, if you're used to driving on a tire like that you won't notice, but if all you've ever driven is cars with low profiles it it very noticeable.
Old May 30, 2013 | 04:24 PM
Tubby's Avatar
Thanks for the reply.....I really don't know much about wheels and tires. Right now I got BFG All-terrains on there. They are 265/75/16I ......i know you said i could go with a 315/75/16 and think that would be great. However I have been looking around at some different wheels and some of the ones I like are 18....so my next question is can i still go 315/75/18? And what time of lug or offset would i need
Old May 30, 2013 | 04:39 PM
Tubby's Avatar
No I haven't gotten an alignment done since I put on the kit. My biggest problem is I don't know much about vehicles so its a good thing I found this place. Thanks for all the advice guys I really appreciate it
Old May 30, 2013 | 06:13 PM
skeeter's Avatar
if you get 18s, you will want to get a backspacing of 4.5" because they look they best, but you don't want back spacing of more than 5.5" I run XD Spys with Nitto Trail Grapplers in a 295/70/18 which is almost the same size as the 315/75/16s. You could also get a 35/12.50/18. I run 4.5" backspacing on mine, and the other thing you want to make sure you get the hub bore at or bigger than 100mm.
Old May 30, 2013 | 07:38 PM
staggs's Avatar
make sure get an alignment ASAP, that will fix a lot of your weird feeling.
Old May 31, 2013 | 08:05 AM
tubby right now you have a 32" tire on there, and your probably thinking to yourself that they look really small expecialy now that you leveled the front. you should def go bigger. 35" seem to be a common favorite amoungst h3 owners, I am pissed now that i didnt buy some when i had the chance. I was to cheap to spend the extra $300 so i got 33" instead. they still look good but not as good as 35" would.
just know that your gas mileage will take a hit expecially if you go with an agressive tread.
Old Jun 4, 2013 | 03:02 AM
Kevwood's Avatar
Agreed. During my build I was going to put 33s on but after seeing the 35s and getting confirmation from a lot of guys on this site that they will fit leveled, I went for them. The H3 looks great with them and drives great, no issues here whatsoever, just waiting on my new suspension now.
Old Jun 12, 2013 | 02:55 PM
Tubby's Avatar
well im glad to sat it wasnt my shocks that was causing me problems. it seems i had the torsion bars cranked down too tight and thats what was causing my issues. the shocks where too tight to do their job and the "sloppy" feeling i had was the actual tires bouncing. i was set to but a complete set of bilstien shocks tomorrow, but wanted to make sure 100% thats what was wrong before i dropped $400 bucks down. luckly for me i have a few connections to a jeep,dodge, and ram dealership they found the problem in no time. guess i will take this as a lesson learned. thanks everyone for the advice
