fan not working on 4 setting
anyone else had this problem? My09 H3 Ac fan does not blow when I turn it to the High speed #4, if so can you help me , It works on the other 3 speeds just not on 4, Is it a fuse, switch, relay ?
fan problems covered 419 times. last time was,,,yesterday,,,you might just look for a post about blower fan,etc,,,not far from where u r !!
Did you ever find a solution? |
hope, its 7 years...
GM recall
[QUthereOTE=Mitchell Glover;352830]
Did you ever find a solution? [/QUOTE]There is a relay that overheats and burns the contacts, located Under passenger side footwell, right above where the floor mat ends. If you don't want to bother with recall issue, part is between $30 & 40. Not difficult to change depending on how bad wiring and connected are damaged. Good luck. Don |
| All times are GMT -5. The time now is 06:32 AM. |
