fan not working on 4 setting
anyone else had this problem? My09 H3 Ac fan does not blow when I turn it to the High speed #4, if so can you help me , It works on the other 3 speeds just not on 4, Is it a fuse, switch, relay ?
[QUthereOTE=Mitchell Glover;352830]
There is a relay that overheats and burns the contacts, located Under passenger side footwell,
right above where the floor mat ends. If you don't want to bother with recall issue, part is between $30 & 40. Not difficult to change depending on how bad wiring and connected are
damaged. Good luck.
Don
Did you ever find a solution?
[/QUOTE]There is a relay that overheats and burns the contacts, located Under passenger side footwell,
damaged. Good luck.
Don
Selandbe
Nov 12, 2015 01:44 PM
Mac77fox
Sep 8, 2014 08:15 PM
