Truck Bed Drain??
Compressed AIR
HI,
My 07 did the same thing before i installed the bed cover,,I used a high pressure air line and blew the un wanted water out..I'm sure the drain holes were clogged on mine...mud does that...LOL...
MC
MC
Clean it!!!!
First you must pull the plastic liner out of it. If there is standing water under it and it stays there it will create rust. So you must remove the water completely and then dry it out. Once you remove the liner you will be able to get to the four drains. You can use a flat screw driver to clean out all the mud and gunk. After you have done that reinstall the plastic liner. Try to keep the drains free of mud and debris as this will help the water drainage.
I have to do this to mine from time to time. Good Luck!
Eddie Omegax
02-05-2015 11:08 AM
Jett
17
06-24-2008 09:52 AM
