Engine not starting
Was changing the ignition switch successful? I have an 07 H3 that is doing something very similar. Turns over but won't start. Wait 15 mins and starts right up. I've got a friggin 30k truck parked. Has GM put out a service bulletin on this. New member here, I appreciate any assistance.
is this it?
ACDELCO Part # D1462G {#15795321, 15795322, 15795324, 19149942, 89060589, D1403G, D1405F}
HOUSING,IGN & START SW w/4-SPD A/TRANS(M30) or STRG COL(NP7-EXPORT); HAS SHAFT LOCK, INCLS PASSLOCK SENSOR, SWITCH; w/o RIGHT HAND DRIVE(RHD)
HOUSING,IGN & START SW w/5 SPD M/TRANS(MA5) or TILT STRG COL(N33) or STRG COL(NP7-EXPORT); HAS SHAFT LOCK, INCLS PASSLOCK SENSOR, SWITCH
okay guys... really need some help on this passlock sensor! I changed it.. the truck would not start.. waited 10 minutes.. started up.. turned it off.... wont start.. 10 minutes.. it started.. Put the old one back in.. works fine.. and once in a while it gives a problem.. so after I put the new one in, do i need a ECU flash or something so the truck can accept it?
HEEEELPPPPPPPPPPPPP!!
Lms Scratch
12-17-2014 02:30 AM
Ghost Rider
08-22-2012 02:43 PM
cqaurich
09-30-2010 07:50 AM
Big D
08-22-2009 06:44 PM
