Emissions Question
Emissions Question
My 2008 H3 won't pass inspection. Two computer monitors not ready, evap system and O2 system. I have tried driving it through the drive cycle two times now with the same result. What can be the problem? It only has 104k on it. I am overdue on inspection and tags so I need help.
I followed the drive cycle as well as I could. Have driven it twice now and will try again tonight. I have to wait til night time for (a) less traffic and (b) so LEO doesn't see my expired sticker. I only need one more to go into readiness mode to pass inspection.
The evap monitor won't run until the fuel level is low enough - usually around 1/4 tank. There has to be a sizeable air pocket over the fuel. Curious why the O2 monitor won't run. I'll check on the requirements later today at work.
Quick update; fuel level should be between 1/4 and 3/4 full, ambient air temp should be over 40 degrees. I have access to Motologic and Alldata but information as to specific criteria to run the individual monitors is not listed. I have had some success with the Tech 2 scan tool running the evap test manually.
haiminger
09-24-2007 02:29 PM
