Driver's Side Mirror Vibrating
Hi,
Just wondering if anyone has the same problem with the driver's side mirror vibrating or shaking when travelling at highway speeds (i.e. ~100km/h or 60mph). I had send it to the service centre and they told me that it is a problem on all Hummer H3 which I find hard to believe. If this is the case, then the quality is pretty appaling given that my car is only a few months old. Looking forward to hearing from other H3 owners out there. Thanks for your help in advance! :) |
RE: Driver's Side Mirror Vibrating
How bad are we talking about. Mine you can see vibrating just small amount but nothing to worry about.
Both of my H3's have done it, and both times it was a warranty repair.......
My big questions is: After they told you it was a common problem, did they offer to fix it ASAP? |
Same thing with mine...I think I'll have it replaced (Gunner, did it resolve the problem when they replaced the mirror?)..I think I'll get mine fixed when I take it in for buzzing A-pillar trim.
Fixed it both times....
mine does it. I took it apart and it seems the gearing and motro is a little loose on the horizontal. Twice I have taken it apart (just the mirror and mounting plate) and after putting it back together it is tight for a whle.
They said they have tightened it up. They did not replace it as they said was not fixable because all Hummers do it.
How bad is the vibration? Well, it is pretty annoying on the freeway when you are trying to change lanes. IF you were looking at it all the time, it would be enough to cause you an headache. |
ORIGINAL: Gunner_45 Fixed it both times.... |
Getting mymirrorreplaced tomorrow
ORIGINAL: Hummer Guy ORIGINAL: Gunner_45 Fixed it both times.... |
