Driver door seal leaking water into cabin
Has anyone else had similar problem? When I make a stop while its raining or has rained, the water must runoff the roof in towards the door seal. The water pours in and runs onto the heater vent, headlight controls, down the entire inside door panel. After some inspection, I noticed there is a gap between where the rubber seal on both the door and frame don't meet snugly. You can actually fit your finger into the gap in the top right part of the door between the two seals. I checked the passenger side, its a tight fit. It doesn't look like the door has adjustment, so maybe to door seals need to be replaced? Do they compact over time? They are in great condition. Thanks!
No, it didn't come with a sunroof. If you poor a bucket of water over the roof/roof rail, the water will leak through. After a close look, the two seals where the door meets the jam arent sealing. There's just enough of a gap to allow water in. My plan is to take it to the dealer to have them look at it, I just haven't had time.
I have the same problem with mine but on the passenger side. my h3 was a dealer demo and they must have noticed this problem earlier because upon some inspecting the problem i saw where they placed some double sided tape between the seal and metal. let me know what you do to fix it
Passenger Floorboard Wet
I am having a similar problem. Both my driver and passenger floorboards were always soaked and I blew out the sunroof drains like everyone was saying on here. Now my driver side hasn't been wet for awhile now, but my passenger side still gets wet. I have been thinking it's something with the door seal, but was not sure. I am going to see if I can find a gap like you said Saturday when I wash it. I am also stationed in Germany so I can't go to a dealer.
