door lock issues PLEASE HELP
Old 11-30-2013, 06:46 PM
luke0405's Avatar
Default door lock issues PLEASE HELP
hello yall
so here is my issue. i own a 2006 hummer h3, i have never had any problems with it until recently. i went to go to town the other day and i started the beast and noticed the locks and driver side window would not work. after some research i found all the little "tricks" to try , i tried everything from taking the positive off the battery to checking and changing fuses, still no luck. so i bought a new master switch. that fixed some of the problems. the window and locks work with the vehicle started or the key in the ignition, which doesnt do me any good to lock the doors with the key in the ignition as you all know it will unlock its self. so the issue i have is the fact that with the vehicle powered off the lock button in the door will not work also the key fob will not lock the doors either. you can hear the relay click but still not locking. if anyone can help that would be awesome i am stressing to the max over this issue!!!!
Old 11-30-2013, 07:03 PM
happythree's Avatar
dont know, but the controller is a module in the driver door sw assm. where all the buttons are.
not to hard to get to it so you might unplug/plug it back in and see??
Old 12-01-2013, 07:35 PM
switch doctor's Avatar
could be a faulty window switch, have you tried to get a warranty replacement on the switch?
Old 12-01-2013, 08:40 PM
happythree's Avatar
theres more than switches and master switches in the h3 driver door.
the solid state module is usually involved in malfunctions. you might update your site diagnosis of window problems.
some have unplugged and repluged it to reset.
bluebow
02-22-2021 10:39 AM
Spike44
10-18-2020 05:57 PM
wpduffey
12-22-2014 05:47 PM
cjmilto
07-24-2014 10:07 AM
BrennMan
12-07-2013 10:39 PM
Quick Reply: door lock issues PLEASE HELP
