Does 2006 hummer h3 base come with a block heater?
Old 11-08-2011, 11:15 PM
RickStang's Avatar
Default Does 2006 hummer h3 base come with a block heater?
I have a 2006 H3 base. I live in Calgary Canada and our winters get to -30 average and -38 with windchill on average. I was always under the impression that my hummer would have a block heater. I just went out and looked for the cord but I couldnt find it. Since daylight savings has been in effect it gets pitch black around 5:30pm so it was dark while looking for it. I'm not sure if my vehicle is from the states or if it is from canada. I am also aware that i can buy a block heater system for around $50.
My question is do the 2006 3.5 h3's come with a block heater from the factory?
Old 11-08-2011, 11:47 PM
No, not as a "standard" item. The Block Heater was an option. theBroken added an OEM block heater to his rig last year and said it was a pretty stright forward install.
Old 11-13-2011, 01:25 AM
skeeet's Avatar
I ordered my 06 with a factory engine block heater. They do not come stock that way.
Old 11-13-2011, 07:38 AM
WBZ's Avatar
WBZ
WBZ is offline
Years ago in the early 80's I had an Oldsmobile Toronado Diesel. I t was 2-3 years old when I got from the original owner who said he did not get the car with that option. I decided a block heater would be a good idea so I bought one and crawled under he car to decide if I would install it or get someone else to do it. What I found was a heater in one of the freeze plugs and no cord so I guess if you ordered the heater they stuck a cord on. Might be worth checking.
Old 11-13-2011, 08:50 PM
drtom's Avatar
Banned
Default Oldsmobile Toronado Diesel.
bak then gm was makin big bucks and die sel needed heat. they could afford to throw it in!!,,id guess,,no more
Old 11-16-2011, 12:19 AM
RickStang's Avatar
I picked up the heater plus the cord for $65. I thought I could install it within a couple of minutes because I'm the kind of person who never reads the directions and just goes at it. I had to remove the alternator and with some fancy tools stuck it right into the correct frost plug. Beats dealer pricing at $350
Old 11-16-2011, 05:01 AM
drtom's Avatar
Banned
were anxiously awaiting pictures!!
Old 11-16-2011, 01:09 PM
Here is an install thread on the heater and where it goes on the I5. Click the link:
Club HUMMER Off Road
Hope this helps others wanting/needing this option!
Old 11-17-2011, 04:44 AM
drtom's Avatar
Banned
there is a way to post a link that will take you direct to the info. the above is not one.
if anyone ever finds that post, just drag the link to your post.
ive done it b4 by viewing the desired info,then draging the site to my post.
my choice of words may not be exact,my methode is!
love to see the pics
Old 11-18-2011, 05:54 PM
RickStang's Avatar
I never took pictures while doing it. Its -25 with wind chill right now so I'll wait until its a little warmer to shove a camera and get a picture of it.
Quick Reply: Does 2006 hummer h3 base come with a block heater?
