Did I Get a Good Deal
Well, I had the dreaded front end oil leak so I took it to a local repair shop which indicated they worked on Hummers. Out the door I paid $830.67 which included:
Crankshaft oil seal
Harmonic Balancer
Serpentine belt
Oil change
And on the Crankshaft seal it say: " Remove & replace automatic trans front. w/grill guard - (includes recover, evacuate and recharge air conditioning system."
Includes: R&I Grille Assembly
Includes: R&I Radiator
I do have an external transmission fluid cooler which bypasses the engine cooling system.
Any thoughts?
Crankshaft oil seal
Harmonic Balancer
Serpentine belt
Oil change
Any thoughts?
As long as your transmission cooler has a internal pressure by-pass cold weather should not be an issue. If it does not, then there can be issues.
I would check your model with the manufacturers specs to see if it does.
As far as if you got a good deal it depends on if you are satisfied and there is no more leak. Sounds like a decent deal for the work you had done.
Coldblooded
01-27-2016 07:35 PM
SEMO H3
113
02-18-2007 02:12 PM
