Dash Dimmer Switch.
Old 02-04-2008, 12:21 PM
WFO's Avatar
WFO
WFO is offline
Default Dash Dimmer Switch.
The dimmer switch on my '07 H3 doesn't seem to work. If I rotate the dial up or down, the dash lights do not seem to change. Is this normal??
Old 02-04-2008, 12:32 PM
Default RE: Dash Dimmer Switch.
They do change but not very much. i believe there has been talk about this in another thread. you can do a search for dimmer issues and should find it.
Old 02-04-2008, 01:25 PM
WFO's Avatar
WFO
WFO is offline
IHNEVELS.........Thanks for the search suggestion. I did do a search, but only came up with one thread that did not have many responses or a resolution. As such, I concluded thatmy dimmer switch issue is not wide spread.
Old 02-04-2008, 04:35 PM
I just went out to my H3 and the lights don't dim that much. I don't know if that helps any, but the switch seems to work just fine.
Old 02-05-2008, 07:23 PM
RealJeep's Avatar
Some things you just never know. I ran my 07 H3 through the full range with the lights on "on" "auto" and "park" and the result was the same each time. They were anywhere from bright to semi-dim but never almost off as most vehicles have the option of.
Old 02-05-2008, 07:36 PM
I do believe i started the thread about the dash lights, they really don't dim much, just a hummer thing i believe? Just figured i'd straggle in and throw my unneeded opinion in there.
Old 02-05-2008, 08:03 PM
WFO's Avatar
WFO
WFO is offline
Okay, so the dash lights don't really dim. I can live with that.[8D]
happythree
09-16-2013 08:24 AM
frankieboy
03-04-2013 12:41 PM
mrvictory1999
10-26-2011 04:56 PM
myfirstH3
03-17-2010 07:09 PM
peliti27
08-02-2007 03:14 PM
Quick Reply: Dash Dimmer Switch.
