Crazy Electric is working backwords (Mirrors, Window Washers, Drivers Window)
Just purchased a 2008 H3 and it seems that the previous owner might have messed with it or it's just freaking out.
1. Drivers side rear view mirror is moving the opposite direction than it should. When I go to push the button to raise it, it lowers. When I push the button to lower it, the mirror raises. ???
2. I replaced the door switches for the windows because the driver window would not work all of the time. It works when it wants to work but when it's not if I pop open the switches and unplug the panel and plug it back in it starts to work again (sometimes). Sometimes I have to completely turn the ignition off and back on before it will work. ???
3. The window washer controls work for the opposite windows they are suppose to work for. When I hit the rear window washer fluid button, it sprays the front window. When I turn the front window washer fluid control, it sprays the rear window. This is obviously electric but I have no idea where to begin. ???
Thanks in advance for your suggestions!
I read a post from a guy with an 06/07 that had swapped his door panels and controls out for the later style door panel and controls and his controls were all off like that. I don't think that's your problem, but thought that was interesting.
JensH2
12-14-2013 02:27 PM
minta7
01-14-2013 09:32 AM
