Coil retainer bolt broke off, HELP!
Old 04-15-2017, 07:40 PM
Chimpy's Avatar
Default Coil retainer bolt broke off, HELP!
Figures that on the last coil that I attempt to remove, the retainer bolt breaks off. It is the front coil. I tried everything I know of to try to remove it. I guess the upper intake will have to come off? Is that bolt only used to hold the coil down. Would I be able to put it back on the plug and drive to a nearby shop, less than 5 miles? I feel soooooo F'ed right now. Any advice will be appreciated.
Old 04-16-2017, 01:09 PM
Kkneat's Avatar
These bolts are just used to hold the coils in place, but I believe if you just lift the coil that the bolts will come off with it.
Old 04-16-2017, 01:16 PM
Kkneat's Avatar
Old 04-16-2017, 01:18 PM
Kkneat's Avatar
Originally Posted by Kkneat
https://imgur.com/a/9i4Is the link incase the pic dose not show up.
Old 04-16-2017, 03:54 PM
Chimpy's Avatar
I put everything back together and it runs fine. I am taking it to my buddy's shop in the morning. I don't have an extractor kit. The plugs in my 2006 had not been changed since new or previous owner over-tightened them. Either way, it will cost me.
Old 04-16-2017, 10:31 PM
Kkneat's Avatar
Really sorry to hear that. You looking to go back to OEM it's the delphi coil pack you will want to get
Old 04-18-2017, 11:50 AM
Chimpy's Avatar
Coil pack is now bolted down. Took it to a retired GM mechanic's house referred to me by my brother-in-law. He drilled out the remainder of the bolt, inserted new threads and it is like new. The hole is maybe 1/2mm-1mm off because it was difficult to get perfectly center for the center-punch. At any rate, it is good now.
micromachine
10-06-2013 09:26 PM
TT_2004H2
01-08-2012 02:42 PM
mooneym20s01
06-25-2011 10:39 PM
H2SS
05-28-2011 02:32 AM
eliminatethis
10-21-2010 09:06 PM
Quick Reply: Coil retainer bolt broke off, HELP!
