Cleaning Undercarriage Help
Old 01-07-2012, 06:59 PM
TSLevin95's Avatar
Default Cleaning Undercarriage Help
I went mudding in my '06 Hummer H3 a few months ago and I still have a lot of dirt on the undercarriage of my car. What is a safe way to clean under it? Can I spray water or will that damage anything. I want to be able to get the undercarriage really clean and nice, without ruining anything. Thanks.
Old 01-07-2012, 10:27 PM
DAGKANA's Avatar
Water will be fine! I use a pressure washer on mine and use my 60" hi lift jack to get her a nice belly out angle...
Old 01-07-2012, 10:37 PM
rsc's Avatar
rsc
rsc is offline
If you're worried about spraying water up under there then you could get a bucket, brush and soap and scrub it clean.
All you really need is a garden hose with a good nozzle and a little time. Try not to spray too much into the axle seals, cv boots or any wiring connectors. While you're under there take a good look around for any damage and general condition. You're more apt to have damage from the trail than that water hose.
Old 01-08-2012, 07:57 AM
wfturner's Avatar
I go to the local do-it-yourself pressure washer
It works very well because of to higher water pressure they use, versus my garden hose
I get down on the ground and have at it
Yes, I end up with wet knees and a clean undercarriage
Old 01-08-2012, 08:19 AM
Mr. Fancy Pants's Avatar
Yur so dirty
Old 01-08-2012, 11:41 AM
First, I get out my home made sprinkler setup with a "Y" fitting so I can run 2. Hook those up to the power washer and let them do their "business" for about 10 minutes them move them around 2-3 more times. Next I get out the car ramps (2 sets) then I pull the offending muddy HUMMER on them and get any of the spots I have not assulted with the sprinklers. Under hood I use Simple Green, tire brushes (long and short handles) and the garden hose. Rattle can on any rust spots.
Looks really good once it's all done. But in the winter I try to stay away from the muddy stuff because I won't do all those steps!
Old 01-08-2012, 05:22 PM
rsc's Avatar
rsc
rsc is offline
I guess too many of us yee-haw types have dropped mud all over the car washes so many places won't let you spray down muddy vehicles. I wonder if they are recycling water or if the drains just got plugged up with mud.
Old 01-08-2012, 05:48 PM
I go to tis place called Delta Sonic, if you buy a premium wash you get two free after. They usually frown when you roll in with mud on the vehicle.
Old 01-09-2012, 07:22 AM
wfturner's Avatar
I have used my local wash place several times over the years and the manager walking around has never said anything to me.
I may not have as much mud or clay as some other vehicles, maybe that is why he hasn't commented. But you are right, some wash bays I've seen have been a mess.
mt2ut1
01-01-2017 10:07 PM
Poncharella
05-12-2012 12:41 PM
TerrySW
04-24-2010 11:47 AM
Trey124
12-03-2006 10:18 PM
importkiller
09-14-2006 07:53 PM
Quick Reply: Cleaning Undercarriage Help
