Cleaning the sun roof drain tubes
Old 06-20-2018, 06:42 PM
Mitchell Glover's Avatar
Default Cleaning the sun roof drain tubes
i have a 2006 h3 Hummer and the water is overflowing from my sunroof and getting all over my car. Their is sitting water in the sunroof and I need to clean out the tubes but I don’t want to take my whole dashboard off any suggestions?
Old 06-21-2018, 08:17 AM
Sorry about your clogged tubes.
Time to learn how to use the search function as Doc suggested in your other post. There are soooooo MAAAAAANY threads on this... EVEN YouTube VIDEOS! Not terribly hard to do.
Does it have a sunroof? If so, your drains are plugged. Search the fix.
If no sunroof, then look to see if the bolt at the front of the roof rack track
has come loose, or if the plastic track frame has cracked.
Old 06-21-2018, 11:27 AM
Here is the good one on the topic. https://www.hummerforums.com/forum/h...n-tubes-28548/
Please also start using the H3 section for H3 questions.
Hoff
01-15-2019 06:34 PM
Odzihozo
04-06-2017 06:11 PM
Ordieh
08-08-2016 08:11 AM
mgurgone
10-31-2011 10:16 AM
Quick Reply: Cleaning the sun roof drain tubes
