Cel-p0171
Old 10-29-2012, 05:43 PM
Default Cel-p0171
Hello Everyone-
I am new to the forum, but thought this information may be helpful. I recently started experiencing intermittent CEL. HP tuners revealed a P0171 (lean bank 1). I changed my upstream 02 sensor, and the light remained. I had taken off my throttle body once before to clean it, so I decided I would disassemble that whole upper assembly that sits on top of the manifold. Sure enough, I found a cracked hose (figured it could be a vacuum leak). The hose is underneath the back of the big plastic piece that site between the TB and the air filter box.
Here are some pictures:
Taking it off was pretty easy. two bolts hold the plastic piece to the manifold (10mm, like most bolts under the hood)
Then Loosened the Hose clamps (four, flathead screwdriver)
The cracked hose that connects from the large plastic piece to the manifold
The New Hose ( I chose to use hose clamps):
The CEL is now gone! Hope this helps.
Old 10-30-2012, 02:30 PM
The "big plastic piece" is known as the resonator box. The hose under the back to the breather port at the rear of the left valve cover is the secondary PVC hose.
Thanks for the thread, might give people a place to look for their leak when they get a P0171.
Old 10-31-2012, 12:17 PM
Smittro's Avatar
Thanks for the write up.. Oh, is that a WS6 T/A I spy there?
Nice choice in toys! Former owner of a 01 Camaro myself..XD
Old 10-31-2012, 10:50 PM
Thanks guys. Yes, it was a 2000 ws6. It's now a shell. Most recently an iron 346 and a pt8847 came out of it. Bigger motor is going in, same turbo though.
Old 03-25-2013, 01:38 PM
UPDATE:
Still no CEL light months later. Replacing that little hose has fixed the issue.
Old 03-25-2013, 09:59 PM
Good to know.
Actual part# 15123628
Chris
Mighty455
06-27-2015 08:50 AM
jerferg
10-28-2013 03:23 PM
TSLevin95
01-19-2012 10:14 AM
06h3lux
01-07-2012 10:07 PM
ken haukaas
01-11-2011 08:14 PM
Quick Reply: Cel-p0171
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
