Carpet Available?
Anyone has a source for carpet, new or good used?
My carpet got wet from a clogged / disconnected sunroof drain, and the rear passenger carpet is worn through in one spot. Maybe a PO spilled something corrosive on it. I will probably have to lift up the carpet to dry it properly, so I might as well replace it at that time. |
I'd guess new carpet isn't available anymore since there isn't any listed on ebay. Since your carpet has a hole worn in it, best bet might be to find some in a junkyard (hopefully H3 with doors/windows still intact or one that has just come in so no mold). A couple of options if it is dirty like mine was. Oh, this is how I bought it, the PO apparently didn't believe in cleaning.
https://cimg5.ibsrv.net/gimg/www.hum...e98e38ef37.jpg Powerwash it. Works pretty well but doesn't get out really bad stains. Mine also had some fairly bad wear that showed up as a black spot in lower right of this picture. It was also wet on passenger's side rear, rear fender flare clips let water in (likely for years) and cargo area pad was soaked as well. Evidence of previous water under passenger front from sunroof drains, but drains were modified and that area wasn't wet anymore. It looked good enough I probably could have just put it back in, but I wanted better. https://cimg6.ibsrv.net/gimg/www.hum...ce633990db.jpg Dye it. Youtube videos on this, pretty easy and cheap to do. Would be better to start with gray/black carpet if you want it this dark, I had to go over it several times and used quite a bit of dye (but still only $8 worth). Color is more uniform than it looks like in the picture, flash catches the carpet nap and reflects oddly. https://cimg8.ibsrv.net/gimg/www.hum...674070e3a6.jpg Turned out pretty good. I painted the driver's rub pads with plastidip to finish it off. BTW, seats were pretty nasty too, got them cleaned up pretty well although they show a bit of wear (183k miles and likely never cleaned). Rubber floor mats are new. https://cimg2.ibsrv.net/gimg/www.hum...ca71eabbe4.jpg |
Originally Posted by Coolvibes
(Post 358159)
My carpet got wet from a clogged / disconnected sunroof drain, and the rear passenger carpet is worn through in one spot. Maybe a PO spilled something corrosive on it. I will probably have to lift up the carpet to dry it properly, so I might as well replace it at that time. I have an Ebony (black) carpet set for the H3. Very heavy. PM me inf interested. |
Originally Posted by TAINTER
(Post 358243)
Where are you located?
Originally Posted by KEAB02
(Post 371606)
Do you still have?
(Post 371606)
Do you still have?
(Post 371659)
Where you located? How much?
The carpet was a take out from the SEMA MOAB show truck. They took the new Ebony out and installed Cashmere. I have the Ebony from that H3. Price? This well used one on ebay is $400 shipped. Make me an offer without shipping. You will pay whatever it cost to ship to you. https://www.ebay.com/itm/2006-Hummer...4AAOSwubdeTKg- |
Visit any carpet cleaner or installer store, they probably have a carpet for you.
The carpet looks great, can you tell me where you bought the floor mats at?
Originally Posted by Fury1967
(Post 392186)
