A/C Off, No Temp reading Help appreciated!
Forgot to post this earlier, but the following day after replacing the thermostat ac started working, temp gauge is working like normal, and has been working since then. It's been over a week now and no issues. Hopefully it stays this way.
your AC started working after codes were cleared by next day
thats the only reason
enjoy the cool breeze
My AC OFF message came on and my temperature gauge dropped to 0. After reading this forum, I removed the PCM-B fuse and put it back in. Everything started working correctly. My check engine light had even been on for several months, and now it is off. Hope this helps someone else.
I've got a 2008 inline 5 cylinder H3 with around 142k miles on it. Had the AC off message problem where the engine temp gauge wouldn't reach operating temperature and it would tell me I couldn't run AC.
I replaced the thermostat and the temperature sensor and the problem went away for a few months.
The problem has returned. When I start up in the morning the temp gauge doesn't go but a mm above the bottom mark before dropping completely. By the time I get home the engine is up to temp (the gauge still shows nothing and the message is still present) and I can clear the message by either disconnecting the battery or pulling the PCM-B fuse. When I start the engine the temperature gauge immediately reads like its' supposed to, AC works, everything is good. I'm having to clear the error every time I want to drive after it's been sitting for a few hours. Has anyone else had this? Is there any other thing I should try? I confirmed the thermostat works by reving the engine at idle and observing the coolant flow. If the sensor was bad, wouldn't it still not give a temperature reading even after cycling the PCM-B?
The temp sensor is an electrical part, it senses heat and relays voltage which is displayed as temperature. If the CTS it is defective, it can work at times, and not others because the PCM cannot interpret voltage beyond the pre-programmed expected range. In other words, its short may not be consistent over time, it may be high, low, or dead. Think of a flickering light bulb, it may work for a couple days before it completely pukes.
If you are sure it is reaching proper temp., Coolant Temp. Sensors are cheap and easy. Try that.
hi I have the same problems ...so the ac off will appear on my dash and temp gage will be down but will comeback if I play around with the ac swith for few min and w
stay on (AC FULL COLD) but the next day after starting the car for 10 min will goes off again and back to square one ...please help
