Broken header bolt.
Old 02-26-2012, 01:16 PM
nyff395's Avatar
Question Broken header bolt.
After trailing home from up north starting hearing an exhaust leak. I found the back cylinder front header bolt is broken off. Is this common and covered under warranty? Hummer H3 X with 55,000 miles. I was towing a 2 place enclosed snowmobile trailer.
Old 02-26-2012, 03:11 PM
2wheelmonster's Avatar
Is the head of the bolt broke off or do you think it broke off part way down the stem?
Did you have any work done on it recently where the header would have been taken off?
The only situations I have run into this is when a head gasket job was finished and the mechanic torqued these bolts down too much and this is the result. I haven't run into a bolt just being broken off after all these miles with no work done. Call the dealer also to see if it is covered under your warranty.
Old 02-26-2012, 05:26 PM
Take it to the dealer. Should be covered under the 5/100K Powertrain Warranty. I have heard of this on a few I5s but not a ton of them.
Don't mention anything about how it broke. Just tell them you have an exhaust leak and that you think the exhaust manifold bolt is broken or the manifold is cracked.
Old 02-27-2012, 06:41 AM
nyff395's Avatar
Just the head broke off and I did have the tranny replaced about year and a half ago. I not sure if the header was touched. We'll see what the dealer says. If not i'll start soaking the bolts.. thanks..
Old 02-28-2012, 09:17 AM
I've seen a couple, and heard of many where an exhaust manifold bolt snaps off. Steel bolts anchored into Aluminum with a pretty fair amount of vibration can cause it.
If you plan on removing the exhaust manifold, plan on more broken bolts, they usually break at the deck surface. I would say you would be living right if you can remove the exhaust manifold from an I5 without breaking a single bolt.
bruceg
20
05-27-2013 11:03 PM
bwhntn
06-10-2012 07:27 PM
skeeter
26
04-25-2012 09:20 AM
Indy
07-12-2011 02:37 PM
silverwarrior
02-20-2010 10:17 AM
Quick Reply: Broken header bolt.
