brakes problems/4x4 problems
hey folks, one last problem I had and I been looking for a solution online but no luck.
1- there are 3 4x4 options one that is standard and then one that have a lock logo with arrow up and arrow down.
my 3rd one with 4x4 lock arrow down when I press on it. it flashes few times and it goes away and doesn't let me select it, what causes this???
2- if I choose any 4x4 options. I notice that sometimes when I brake. the brakes are delayed like I press on the brake pedal and then after few seconds the braking happen. its not instant like it suppose to be. what might be the problem??
thanks a lot guys for helping me out. I been fixing the hummer to get it back to go again.
The one with the down arrow is your 4 Low. It can only be engaged when your transmission is in neutral and works best when rolling 3 or 4 miles per hour. The brake issue is unrelated. I suggest you read your Owners Manual. If you don't have one, it can be downloaded at Hummer.com
BrianDye
03-04-2014 09:35 AM
DZLROKET
02-08-2010 04:13 PM
jbugharrison
09-03-2009 01:15 AM
