BFG A/T 305/70R16 on stock rims rubbing...
Old 01-01-2008, 11:03 PM
novasaigo's Avatar
Default BFG A/T 305/70R16 on stock rims rubbing...
I have a2007 H3 Base model with a front leveling kit even front to back. I had BFGoodrich All-Terrain T/A KO 305/70R16 installed on my stock rims.The inside front of the tires rubon the tubular metal bar when I turn the wheel all the way right or left. It has left an obvious black mark.
I want to keep my new tires mountedon my stock rims.
Would wheel spacers resolve this issue?
If so what is the minimum size and where do I purchase such an item?
Old 01-02-2008, 01:24 AM
Default RE: BFG A/T 305/70R16 on stock rims rubbing...
That's the swaybar.
Stock tires will even rub the swaybar sometimes when turned at full lock. I wouldn't worry about it.
Old 01-02-2008, 05:17 AM
hilljob26's Avatar
not too big of a deal,just remeber when at full lock,ease up a lil,it will still turn on a dime.
Old 01-02-2008, 07:27 AM
ORIGINAL: hilljob26
+1 on hilljobs post, shouldn't be a problem if your rubbin' a lil bit at full lock. Bigger issue may be those white letters on the inside of your tires, get you a perminant marker and black those things out man ! Les C. in Macon,GA.
Old 01-02-2008, 07:58 AM
alrock's Avatar
Hey, the truck looks good. You may have helped me with my next tire purchase, though I'm not putting on the leveling kit unless necessary to fit the tires. [/align]
Old 01-02-2008, 09:05 AM
you can go with a small spacer with no problems.....bigger rigs than the h3 have been running them for years. If you get a spacer plate just make sure you have enough lug threads left to get through the lug nut. If you go with a one inch or more spacer get the kind that the spacer mounts to the hub using the original lug nuts ...bolts on like a rim...then the spacer itself has it's own set of lug bolts..I'm using a set of these from spyder in the Jeep.
Old 01-02-2008, 09:06 AM
tnd2's Avatar
Thats a good looking setup, but can you add some more pics from the front or rear and how about a full on side shot? Just getting our H3 tonight and been trying to decide tire size & brand, etc.
Old 01-02-2008, 10:08 AM
SteveO's Avatar
Looking good Nova, I have the same tire but the 285 /75/16really happy with the tire. Are the 305's 34 inch?
Old 01-02-2008, 11:45 AM
novasaigo's Avatar
Thanks to everyone for the quick replies and information.
I definitely want to stop the rubbing it annoys me and scares the crap out of any passengers.
I constantly hear " [sm=WTFsgign.gif]was that?"
By the end of the day I find myself checking the tires to see if the inner lugs have torn off.
SteveO - Thanks. I believe that the 305/70R16 are 33" tall and 12.2" wide
tnd2 - Here you go...
importkiller - Excellent information. Any advice on the best place to look for price and quality?
alrock - Glad I could help.
LesC. - Thanks for pointing out the white letters.
Now I'm going to have to black them out. [:@]
hilljob26 - Thanks for thecomment on the turning radius. I was wondering about that.
Sewie - Thanks for naming the tubular metal thing for me.
I almost didn't post thisfor lack of knowing what it was calledand decided a picturewould be better than any description I could think of.
Nova...
[sm=crossbonesgif.gif]
Old 01-02-2008, 11:48 AM
tnd2's Avatar
Your 285/75r16 should be 32.8x11.2, and the 305/70r16 should be 32.8x12.0 mathematically(had to use spell check for that one) anyway. The real size could be diffrent and only determined by a tape
Quick Reply: BFG A/T 305/70R16 on stock rims rubbing...
