Anyone change the brakes on the 2006 h3 yet....
Old 10-19-2008, 05:05 PM
thehammerh3's Avatar
Default Anyone change the brakes on the 2006 h3 yet....
I am getting alot of squeeks from the front brakes now so I was curious if anyone has changed it and about how long it took? Any special tools required for the hummer h3? Anyone take pics?
Old 10-20-2008, 06:19 AM
BMJM100's Avatar
Default RE: Anyone change the brakes on the 2006 h3 yet....
I changed mine about 6 months ago, about 35K miles. I wasn't squealing yet but was really getting done there, so I changed themso I didn't have to touch myrotors. Itonly took me 20 minutes a side to do, I ended up buying a couple of cans of brake cleaner and cleaning up everything and painting my brake calipers at the same time, came out mine!
Good Luck! [sm=gears.gif]
Old 10-20-2008, 04:34 PM
Any special tools required or no?
Old 10-20-2008, 07:02 PM
lordlang's Avatar
I had 35k on my '06 and they were squeaking a little at the very end of every stop. I took the wheel off the front one and there was at least 50% pad left. So I took it in to the dealership and they replaced all 4 for free, saying the new 08's have "upgraded" pads and they've been getting a lot of issues with the '06's. Not really sure what the issue was though..
Just thought I'd mention that..
Old 10-21-2008, 08:42 AM
BMJM100's Avatar
No special tools needed, if I remember right I used a 18mm socket, screwdriver, hammer, a hex head (can't remember what size). If you have all the basic tools in aset, your all set. The only thing I went to buy was a cheap large C clamp to close back up the piston on the caliper and that was about $8.00 at Ace True Value.
Old 10-21-2008, 02:58 PM
branstone's Avatar
i would search and see the other threads
this was the easiest brake job i have ever done, you do not even take the calipers off
Old 10-22-2008, 07:52 PM
Well I will be doing it this week so I will post pics of the process for everyone.
Old 10-22-2008, 11:26 PM
Hey guys new to the form i'm having the same front break issue but not all the time[8D]
Old 10-23-2008, 08:08 AM
HummerGuy's Avatar
ORIGINAL: thehammerh3
Didn't I already talk about this with you
Old 10-26-2008, 07:03 AM
outnabout's Avatar
I have 42XXX miles on mine and rotated my tires last week. I checked the pads at they have plenty of material left, but I did notice that the front rotors are pretty grooved. I have noticed a drop in braking power, but that may be due to me not bleeding the brakes in the 3+ years I've owned the H3. Has anyone done a full brake fluid replacement themselves or did you take it to the dealer? Thanks,
Mike
Quick Reply: Anyone change the brakes on the 2006 h3 yet....
