All dash instruments reading low
Old 05-12-2019, 04:41 PM
Alaskantinbender's Avatar
Default All dash instruments reading low
Like the title says all the dash gauges are reading low. Temp at 1/4 when hot, fuel at 3/4 when full and so on. The gauges all work just reading low.
Its an 09 H3T alpha, really like the V8.
Power issue or blown transistor? Any help is appreciated
Thanx
Jim
Old 05-12-2019, 07:21 PM
Check battery voltage: 12.5v resting & 14.5v charging.
Old 05-12-2019, 07:52 PM
Reads 12.5 resting (off) and 15.5 after start. After running for a few min reads 15.0
We have driven it for about 4 months, nothing seems to be wrong with the charging system.
Old 05-12-2019, 11:18 PM
hummer_on_fumes's Avatar
When I had a similar problem in my H2, the stepper motors in the cluster needed to be replaced. It may be time to get your cluster refurbished since the truck is now a decade old. Do u have any other symptoms like a dim display or bulbs out?
Old 05-13-2019, 07:58 AM
You still using the Crappy OEM Battery Terminal Connectors?
Old 05-13-2019, 05:03 PM
The previous owner replaced all the cluster bulbs with LED's and they are a little dim. Looks like I need to take it out and just see whats what with it.
oceanbrave
08-21-2020 07:32 PM
Mighty455
01-05-2011 04:25 PM
Sooner1
11-22-2010 09:59 PM
Sooner1
09-26-2010 09:55 AM
rlbock
10-17-2007 12:35 PM
Quick Reply: All dash instruments reading low
