alignment after TB lift
Old 12-09-2011, 10:58 AM
mr.spooky's Avatar
Default alignment after TB lift
so,, its aparant to me that i need an alignment. my mesurments are 23.5". it seems that iv read that that after an alignment it raises it a little. is this true, or am i thinking about something else? if its true, then should i lower it a little to componsate?
thanks
spooky
Old 12-09-2011, 12:59 PM
The only way an alignment changes your suspension height set is if the guy doing the alignment cheats and changes your set. Some like to get close, and then tweak the T Bar Bolts to fine adjust it thinking nobody is gonna be the wiser.
If he sticks with just the alignment caster/camber cams any change would be minimal.... like 1/8" +/-or less.
Old 12-09-2011, 04:40 PM
mr.spooky's Avatar
thanks for the reply! ill just leave it be.
spooky
lostsoul77
11-17-2014 01:58 PM
Andreas_Sweden
07-02-2013 02:29 PM
fozzie21
05-30-2013 04:51 PM
digglesworth
04-10-2013 04:25 PM
psych0
04-20-2010 11:08 PM
Quick Reply: alignment after TB lift
